April 19, 2025, 10:03:28 PM *
Author Topic: Car Shutting Down  (Read 6175 times)
« Reply #2045: December 30, 2009, 10:31:38 PM »
so it is shutting down, but then works again after sitting for awhile?   this can be caused by the fets.   it doesn't sound like the fet is blown or it would loose all forward or reverse, or won't shut off.
I'm guessing that is is more then likely a poos solder joint on one of the fets.  you can try and hit each leg of the fet, but you will need a really fine solder tip for it.   I can do it for you and test everything out, but you will need to get the car to me.
LMK.
