April 02, 2025, 04:12:30 PM *
Pages: [1] 2 3 Next   Go Down
Author Topic: Few questions..  (Read 46914 times)
« Reply #2100: January 10, 2010, 10:23:44 AM »
brian i can't figure out how to open my ball dif SadSad
you need to loosen the adjustment screw a little.  then on the end pop off the little e-clip.  then it will come apart.   be careful not to loos the e clip or any of the balls.  Oh when putting it back together I recommend only using 5 of the ball,  alternate them between holes. Make sure you sand the disk nice and flat and be sure to get any coating that is on them off.  Then re assemble and you should be good to go.  it should be nice and smooth action then install.  the gear on the motor will hold the gear, and if you spin one wheel the other should spin smoothly in the opposite direction.
here is a very good diff build tutorial.    Reflex Racing Diff Build Tutorial.
Pages: [1] 2 3 Next   Go Up
