April 19, 2025, 08:11:27 AM *
Author Topic: PN tires  (Read 9272 times)
« Reply #3068: April 14, 2011, 01:10:39 PM »
I go through about 3 sets of rear tires for every set of front.   this is where it's up to you as for what you want to do.   my best setup would be with both new fronts and backs, but I can't afford to change them and always run new tires,  so it's a compromise.   Also the faster you take the corners the faster your tires with wear both front and back.  I can deal with the little push I end up with as the fronts go away, but when it get to bad,  I'll change them.
what you have describes is pretty close for the tires rating.   I'd say the radials and X-pattern are about the same in grip, and wear.   the slicks will be the same as the others worn down. ( or pretty close).
if you have to much rear grip,  you might want to go with the 8's in the rear.  they are a little harder and would wear longer.   the setup depends a lot on your driving, setup and body.  Each body will handle different.    Also the 575 is a 98mm wheel base so take that into account as well.
