January 27, 2025, 08:43:51 PM *
News: Our next race will be Thursday January 30th HFAY Races .  Come Join Us!!
Author Topic: my car is glitching, is the board bad (Started for Ryan)  (Read 10410 times)
« Topic Start: April 11, 2008, 01:05:25 PM »
Quote from: Ryan
You know haw my mini-z was freaking out last night? Well it does it at my house too. So I think its not interfering frequencies with anything.
« Reply #1: April 11, 2008, 01:06:09 PM »
Ryan,  you set the trim on the board to the new controller right?  maybe you need to adjust the trim on the board back.  give it a try.
maybe there is something in that paticular place on the adjuster that makes it go funny.
« Reply #2: April 11, 2008, 02:19:35 PM »
1st - swap crystals (done that)
2nd - try differenct controllers (done that then)
3rd- Try a different board that you know works (done that and still doesn't work)
4rd- test your self for magnetism or radioactive waste.
Ryan
« Reply #3: April 11, 2008, 04:27:15 PM »
I haven't tried a new board yet, but russ said to take off the cover into the steering electronics, and to clean it out, lube it look at it for problems, ETC.(I havent done that yet) I'm not quite sure how to set the trim on the board but I did do it on the controller. The F1 on the same controller and crystals work just fine it's just my 02. If I don't fix it in time for the next race I'm just bringing my 01. I'm going to take off the electronic cover the instant I'm done looking on the forum.
Rubbin's racin'
« Reply #4: April 11, 2008, 04:34:07 PM »
if you can't figure it out let me know,  I'll look at it.
also it could be as simple as the antena wire being broken off on the board.    Look over it and if you need me to look at it I can pick it up and see what I can come up with.
Ryan
« Reply #5: April 11, 2008, 08:16:34 PM »
I took apart the car and bought some compressed air to spray on the steering gears just like Russ said to,so I sprayed it and it worked (so far) Grin I'm so happy Grin It is now perfect. Grin What a simple answer to such a big problem.
Rubbin's racin'
« Reply #6: April 11, 2008, 08:38:03 PM »
good to hear...  Cool
« Reply #7: April 12, 2008, 11:39:58 PM »
Glad to hear you figured it out. These tiny little electronics can be frustrating.
