April 02, 2025, 03:37:54 PM *
Author Topic: Parts in stock  (Read 22062 times)
« Topic Start: May 31, 2008, 04:22:47 PM »
Luke,  the F1 motor mount (blue) and the 64 pitch gears you wanted are instock.
Nic,  the F1 motor mount (orange) the F1 tires and the OL gear cover are listed and instock for you.
« Reply #1: May 31, 2008, 11:21:25 PM »
thank you sir.
« Reply #2: June 16, 2008, 09:48:09 AM »
Bryan I need FXX front clip, and F1 small parts and chassis set?
« Reply #3: June 16, 2008, 11:02:49 AM »
I have the F1 parts in stock.    I'll check on the FXX front clip.
http://www.saltlakemini-z.com/Zen_Cart/index.php?main_page=index&cPath=74_109
Kyosho has closed their dealer site for upgrades,  it'll be back online on July 1st I was told.   at that point I'll be placing my order from them.
if there is anything specific you need let me know and if it's available I'll get it with my order.
« Reply #4: June 16, 2008, 04:09:45 PM »
from what I have seen there isn't a front clip available by itself.   I wonder if the front clip from an enzo is the same??
« Reply #5: June 16, 2008, 10:43:06 PM »
now that is just plain silly, they don't sell front clips by themselves? I have about four bodies then that I am plain out of luck on then.
« Reply #6: June 16, 2008, 10:49:10 PM »
no they have them,  just not for the FXX (as far as I can tell).   it might be the same as the regular enzo.  As soon as there site is updated and I'm able to login I'll check and see if it's available.
« Reply #7: June 16, 2008, 11:03:35 PM »
oh sheef thats a relief, sounds good thanks.
« Reply #8: June 22, 2008, 11:44:27 AM »
Brian I need a pair of 6 degree slick front pn tires, they stock them at rckenon but didnt see them at your store, I am trying to get my murci set up right, so I'm goign to try the 6 degrees in the back and the hardest wide tire I can find in the front, I think that is a 20 I have 8 degree in the back and kyosho 20 wide in the front but its still not working. So maybe with these sixes it will help, I can also just put some stock wide tires on the front I heard those are 40 degree? Any who let me know when they get in along with the balck clk body and I will palce the order. thanks.
« Reply #9: June 22, 2008, 12:16:26 PM »
also would like the bridgestone tire decals porfavor
« Reply #10: June 22, 2008, 02:12:42 PM »
I can get you the 6's but you sure you want to go with that much grip in the front?   it will tend to cause you to spin out.   I'll get them if you want them though,
No problem on the bridgestone decals.
« Reply #11: June 23, 2008, 07:33:27 AM »
no you are confusing my super wide rears wiht a regular set up the 6's are for the rear I need one wide and one narrow for each rear tire, so I need them to match six wide six narrow I think they only come in slick for both front and rear to match. The front will be something along the lines of 15 20 or 25 I will need to play with it. thx.
« Reply #12: June 23, 2008, 08:09:10 AM »
no problem,  I'll get them on my next order.
