November 23, 2024, 01:13:59 AM *
Pages: [1] 2 3 Next   Go Down
Author Topic: MR-02MM on the way..First upgrades?  (Read 29858 times)
redbarton
« Topic Start: December 24, 2009, 01:05:07 PM »
I have one of these in transit to me.  I have about $50 that I can add to it for upgrades.  What should I do first?  I assume tires first?  Motor too?  If so, what is the right one?  Suggestions would be much appreciated!
« Reply #1: December 24, 2009, 02:04:11 PM »
Here is what I would start with.
Tires:
PN 6* treaded Rears
PN 10* fronts
I personally like the 15* for a little push
PN 15* fronts
Bearings
HFAY 70T Motor
then go for some stainless king pins and then springs.
« Last Edit: December 24, 2009, 02:29:32 PM by briankstan » Logged
« Reply #2: December 26, 2009, 08:17:04 PM »
Rod,  I'll compile a list of all the parts that I put on Andy car for you.
I should have everything in stock that you will need.  I can get you a price and bring everything with me to work and you can pick it up.   Or if you'd like you can drop off your car and I can set it up for you.   Just let me know how you want to do it.
redbarton
« Reply #3: December 26, 2009, 10:51:37 PM »
Sounds good.  I'll probably have to break it up into part I & part II.  I made a quick list myself earlier and it came out to somewhere around $150-175.
« Reply #4: December 27, 2009, 03:37:19 PM »
Definately get some tires first. For $50 to start I would get 2 pairs rears PN RRR06 work great. Then I would get some fronts. I like RRF08 radials or RSF06 slicks but others like a little harder tire for a bit of push so get a couple to try out and see what you like. Then I would definately get some bearings. I like the (PN 600120 $8.95) cheapie's myself but you have to clean them out good. I run mine dry. You can polish your stock king pins and that works great. You might want to get a spring set for the front, they are cheap and can help tune the car to your likeing. I like the low down kind (MR2090) for a little front droop.
So to break it down (in my opinion of importance) for $50 or less:
1. Tires 2 front 2 rear = $15.96
2. Bearings $8.95
3. King pins polish $free (if you have the polish and a drill or dremel)
4. Springs $5.99 (I have a set of low down springs for $5 brand new if interested)
5. Wheel nuts $3.99 (not necessasary but nice to have)
6. T-Plates Set $11.95 (PN MR2023)(not necassary but nice to have)
Total $46.84 plus tax or shipping, less discount?.
Next steps would usually be something like:
1. Differential
2. Disc Damper
3. Motor Pod
4. PN70t motor
« Reply #5: December 27, 2009, 05:21:11 PM »
Russ,
he had asked that I setup the car the same as I setup Andy's car.   He Test drove it on Saturday and really liked how it handles. it's the same setup that I have on my car with the exception of the PN A-Arm.  We went with 1 degree knuckles and 1 degree caster with PN 6 rears and 15 fronts.  it's a very neutral car.  We had 10 fronts on it initially and it was just a little twitchy.  the 15's calmed it right down.
I'll post the complete setup here when I have time to type it all out. Smiley
« Reply #6: December 29, 2009, 08:34:12 AM »
Here is Andy Complete Setup that is on His MR-02 MM Car
It’s setup at 98mm Wheel base
Full Bearings
Rear:
PN Diff with Ceramic bearings and PN Ultra Light weight shaft
PN 94/98 Multi Length Motor mount.
PN Graphite Multi Length damper,  sanded plate and disk with 2000 grit. (removed all sharp edged) Blue spring on top / Green on Bottom.
PN Dual Action Top Shock.
PN 6* Radials
Front:
Stainless Kingpins
2* Knuckles ( I personally like 1*)
1* Caster Bar
Yellow low Down Springs,  with limiter and stock preload bushing installed.
PN 15* Slicks
redbarton
« Reply #7: December 29, 2009, 04:04:46 PM »
Thanks for taking the time to type out this list, Brian.  Now the bad news...My car won't be here until 1/6. Sad
Does anyone use the WTF by Reflex Racing?
http://www.reflexracing.net/proddetail.asp?prod=RX1135BL
Just curious...
« Last Edit: December 29, 2009, 04:06:18 PM by redbarton » Logged
« Reply #8: December 29, 2009, 08:24:52 PM »
it's a good setup for a mod car.  the it allow you to have the +3 offset with running 0 offset wheels.  it's too wide for most of the stock bodies.
« Reply #9: January 06, 2010, 08:08:03 AM »
when you car arrives let me know what you want to do and I can help you select the right parts for it...
redbarton
« Reply #10: January 06, 2010, 12:08:27 PM »
UPS shows it out for delivery today.  Woohoo!  I'll post an update later when I see what I have to work with.  I know it has a few upgrades, but I'm not sure which.
I don't think I'll make racing tomorrow, but I'm planning on Saturday.
I'm also trying to track down a Mini Giant.  There's a used one on Ebay right now I might bid on.  I've always wanted one.  This gives me a good excuse to buy one finally.
« Reply #11: January 06, 2010, 12:48:12 PM »
the mini giants are sure fun,  they are very durable as well.  Unless you go crazy (I do that sometimes).
As for the car,  do you have pics or a link and I can see what is on it.?
« Reply #12: January 06, 2010, 03:30:01 PM »
The only Mini Giant on ebay has been on there for some time you might want to offer the seller like $80 shipped or something. Its got a few nice hop-ups on it so I would say its pushing the limit at $95 shipped but decent. I saw one go just the other day for about $50 shipped. They come up every now and then so If you arent in a hurry just keep your eyes peeled. I usually will post up on SLMZ whenever I find a good deal on a Mini Giant or a Helios radio. Just keep an eye out on the private general discussion for the "Good Deals I found on Ebay" thread.
P.S. FYI I got a bunch of stock replacment parts for the Mini Monters.
« Last Edit: January 06, 2010, 03:39:20 PM by Russ » Logged
redbarton
« Reply #13: January 06, 2010, 03:40:07 PM »
My wife gave me a call at work and said the package has arrived.  Woot!  I'll be home in about 2 hours and will post up some pics then.
The only Mini Giant on ebay has been on there for some time you might want to offer the buyer like $80 shipped or something. Its got a few nice hop-ups on it so I would say its pushing the limit at $95 shipped but decent. I saw one go just the other day for about $50 shipped. They come up every now and then so If you arent in a hurry just keep your eyes peeled. I usually will post up on SLMZ whenever I find a good deal on a Mini Giant or a Helios radio. Just keep an eye out on the private general discussion for the "Good Deals I found on Ebay" thread.
Thanks for the info Russ.  I agree that $95 shipped is a little steep for that one (with the Hummer body) currently on eBay.  I can do better.  I'll also keep an eye on that thread you mentioned.
redbarton
« Reply #14: January 07, 2010, 12:45:21 AM »
Okay, here's what I got...
The upgrades are slim, but it's a start.  It has bearings, aluminum wheel nuts, an FRP T-Plate, and an Atomic Stock Motor.  There are also a few spare parts in a bag like a motor pod, pinions, and some used tires.  A few tools too...
I also picked this up for it:
It all seems to work.  Let the upgrades begin!
Pages: [1] 2 3 Next   Go Up
