Offline
any tips on getting the eclip back on
I just use a little screw driver.
Offline
 Those little buggers suck. What I do is keep the diff adjuster nut on the other side as loose as possible but threaded on, and push everything towards it to get it out of the way of the slot where the clip goes. Then I use needle nose pliers to position the clip on the bearing with the open side towards the slot in the shaft. Then I turn the pliers up on end so one side of pliers is behind the shaft and the other side is behind the clip. Then I cup my other hand over the end and gently squeeze the pliers till the clip "pops" in. Sometimes it flies away  and thats why I cup my hand around it and always work over a towel to catch it if it drops.
RonNation
Offline
thx, will try some more when i get home from work.. looooooooool
Offline
Ron, Did you get the the diff back together? it should be nice and smooth.
RonNation
Offline
I got it back together but it didn't feel too smooth  . I think I didn't use enough grease and I could have sanded a bit more.. I dunnoooooooooo its frustrating cuz I don't know what exactly to look for while doin these things
RonNation
Offline
also i lost the eclip, can i purchase some spares.. lol
Offline
I have one I can give you.
Offline
Ron, if you need the clip before thursday you can come pick it up before then. Just let me know.
RonNation
Offline
Hey I was wondering if there was some time tonight or tomorrow that I could come over and practice a little bit to try and get my car running well.. If not that's fine I'll just stop by and grab the clip.
Offline
I'm going to have Jace over and help him get his car setup and ready as well. your welcome to come by after 6pm. tonight.
RonNation
Offline
Alright I'll see you tonight.
RonNation
Offline
« Reply #26: February 09, 2010, 12:01:06 AM » |
Hey brian, while searching for a new body(mine is starting to fall apart) what body style do i need to loo for?
That is MR02 RM/MM/etc...
Thanks
Offline
« Reply #27: February 09, 2010, 06:34:25 AM » |
That SLR has been through alot !.
that cars is set up as MM 98mm.
Offline
« Reply #28: February 09, 2010, 10:29:46 AM » |
My Lambo body is 98MM. The Enzo is also. If you click on the "Downloads" just under the "Shout Box" on the left <---, then go to "General" and then select "Auto Scale Chart". In it you will find almost all of the Auto Scale bodies ever made less maybe some of the brand new ones. You could search MZR or Kyosho for an updated sheet. There are also Offset charts that show the wheels you need. Good Luck.
Offline
« Reply #29: February 09, 2010, 12:34:13 PM » |
the 98mm bodies are actually rare compared to the other bodies out there. there are several different paint themes of each of the bodies I've listed.
Lamborghini Murcielago Ferrari Enzo Ford GT McLaren F1 LM McLaren GTR longtail McLaren Mercedes SLR Ferrari 575M Ford Mustang Nissian GT-R Lamborghini Diablo Aston Martin DB9 BMW M3 Ferrari 612 Scaglietti
that's all I can think of. there might be one or two more though.
