April 02, 2025, 04:44:16 PM *
Pages: [1] 2 3 Next   Go Down
Author Topic: Few questions..  (Read 46930 times)
RonNation
« Topic Start: January 06, 2010, 10:59:16 AM »
Is it normal for the car to make a constant noise when you turn it on.. I don't know how to explain it but every time I turn on the car it makes it and it will change pitches depending on turning/throttle..
Also brian, I'll be comin out on thursday, do you still have one of those ball difs? also looking to pick up that other motor
« Reply #1: January 06, 2010, 12:51:22 PM »
I do have a ball diff.   I've sold all the motors I had.  I'll get some more coming.
the car will make some twitch sound,  it's the servos always trying to certer itself.   We typically say it's not a mini-z if it doesn't do that.
One thing to note,  you always want to turn the TX on First, and the Turn it off Last.  this was you won't have a car that can go out of control.
RonNation
« Reply #2: January 08, 2010, 07:15:48 PM »
hey brian, on the rear dampener is there supposed to be a spring above and below it?
edit: nm there are, i think my wife knocked one off my desk and we can't find it so i'll have to grab a new set from ya tomorrow
« Last Edit: January 08, 2010, 07:22:19 PM by RonNation » Logged
« Reply #3: January 08, 2010, 07:47:45 PM »
you need a damper spring?   I'll make sure I have some with me.   did you just want to get the set?
RonNation
« Reply #4: January 08, 2010, 08:04:31 PM »
i dunno, would it be alright if i came over at 8 so i could get setup before we leave?
« Reply #5: January 08, 2010, 08:33:49 PM »
That would be fine.
RonNation
« Reply #6: January 09, 2010, 07:23:01 PM »
brian i can't figure out how to open my ball dif SadSad
« Reply #7: January 10, 2010, 10:23:44 AM »
you need to loosen the adjustment screw a little.  then on the end pop off the little e-clip.  then it will come apart.   be careful not to loos the e clip or any of the balls.  Oh when putting it back together I recommend only using 5 of the ball,  alternate them between holes. Make sure you sand the disk nice and flat and be sure to get any coating that is on them off.  Then re assemble and you should be good to go.  it should be nice and smooth action then install.  the gear on the motor will hold the gear, and if you spin one wheel the other should spin smoothly in the opposite direction.
here is a very good diff build tutorial.    Reflex Racing Diff Build Tutorial.
RonNation
« Reply #8: January 10, 2010, 06:27:51 PM »
how to remove eclip
« Reply #9: January 10, 2010, 06:54:19 PM »
how to remove eclip
a little screw driver, razor knife.  anything small that you can use to pop it off.  Smiley
RonNation
« Reply #10: January 10, 2010, 07:07:51 PM »
which way is it supposed to pop, upward or outward,
nm finally got it off
« Last Edit: January 10, 2010, 07:25:38 PM by RonNation » Logged
RonNation
« Reply #11: January 10, 2010, 08:49:46 PM »
so on one side of the gear there is the metal plate and on the other side of the gear there is the same metal plate that is attached to the copper-lookin part, do i need to sand that plate as well?
i also got team associated silicone grease, will that work?
« Last Edit: January 10, 2010, 09:09:40 PM by RonNation » Logged
« Reply #12: January 11, 2010, 07:05:59 AM »
yes the grease will work.   I would sand both sides of both of them,  this is the surface that the diff balls run on.
« Reply #13: January 11, 2010, 10:26:37 AM »
Here are a couple "How To" articles on building a diff. I'm sure there are more out there if you search.
Atomic Mods How To Here
Reflex Racing How To Here
My best advise is make sure to build on a towel to catch the diff balls that always fall. Keep your hand over the end of the ball diff while re-installing the clip just in case it flies away. I usually suggest building in a non carpeted area as it makes it easier to find if you do drop it.  eek Good luck!
RonNation
« Reply #14: January 12, 2010, 07:44:17 PM »
any tips on getting the eclip back on
Pages: [1] 2 3 Next   Go Up
