April 02, 2025, 03:45:49 PM *
Author Topic: looking for VMG parts  (Read 24787 times)
ronajon
« Topic Start: November 03, 2010, 02:10:46 PM »
hi there,
just dusted of my vmg for my kid to play with, but it seems there are some parts that need replacement.
i looked al over the internet already for spareparts but with no luck until now (i hope  big-grin)
the parts im looking for
hex 7 battery pack ven-1533 (or if possible some battery mod, perhaps lipo or DIY?)
gear set ven-4410 (one of the gears is missing teeth)
fireball 370p motor (seems to be the easiest to get, venom racing still has it)
« Reply #1: November 03, 2010, 02:31:29 PM »
You can get a battery pack at most hobby shops,  just ask for one that has a mini-t connector on it.   I'm running a 6 cell in mine.
As for the gears,  do you need the pinion? or the tranfer case gears?
I've seen the fireball motor on ebay for a very good price.  that what I run in mine as well.     Let me know on the gears.  I know I probably have some.
ronajon
« Reply #2: November 03, 2010, 02:52:11 PM »
just found and bought the transfer gears on ebay:
http://cgi.ebay.nl/ws/eBayISAPI.dll?ViewItem&item=380258182754&ssPageName=ADME:B:EOIBSA:NL:1123#ht_2323wt_936
bought 2 set to be sure.
for the battery pack: does it need to be 8,4v 1100mAh (btw is that 1100 per cell or 1100 combined with 7 cells?). and it needs to be fitted in the battery compartiment, so don't know if a 6 cell will fit?
« Reply #3: November 03, 2010, 03:57:30 PM »
what I am running is a 7.2 volt 6 cell pack 1600mah.   it fits in the back fine.  Most of us mount the battery permanent with shoe goo, or you can just put a piece of foam or something to hold it in place.   the 1100 is a the mah rating.  the higher the # the longer the run time.
what you purchased was the servo gears (for the steering servo)  is that what you needed?   I figured you needed driver gears for the transfer case or the pinions that mount to the motor.
« Last Edit: November 03, 2010, 03:59:08 PM by briankstan » Logged
ronajon
« Reply #4: November 04, 2010, 02:03:48 AM »
you are right, i now see i bought the wrong set of gears ...
actually need the driver gears, not the pionions or the steering gears. if anyone has a set of driver gears let me know!
for the battery, i live in holland, we don't have a radioshack or some sort of rc-store in every place. most of the items i need to buy from the internet. does it not need to be 8.4v and / or 1100mAh?
ronajon
« Reply #5: November 04, 2010, 03:55:37 AM »
just found a store where i can buy the battery pack.
there are different voltages / amperes possible, what is recommended?
6v 1300 mah jr bus
6v 1500 mah jr bus
7,2V 1300 mah mini tamiya
8,4v 1300 mah mini tamiya
9,6V 1300 mah mini tamiya
(i already ordered the 370p motor, so that's one item less  Smiley )
what kind of bus do i need for the vmg? tamiya, mini tamiya, bec, other?
« Reply #6: November 04, 2010, 08:16:25 AM »
this it pretty much the same battery I'm running in mine.
7.2V 1600MAH NI-MH BATTERY MINI-T MLST MLST2 DYN1456 - eBay (item 260679916230 end time  Nov-17-10 07:33:56 PST)
this one even has the mini-t connector that you want.   the tamiya connector is different than what the VMG has so it will need to be changed to the right one.
you can run either the 8.4 volt or 7.2volt batteries.  (6 or 7 cell) and the higher the Mah # the better runtime you will get.
ronajon
« Reply #7: November 04, 2010, 09:29:14 AM »
ordered this one:
http://www1.conrad.nl/scripts/wgate/zcop_nl3/~flNlc3Npb249UDkwX05MX0IyQzpDX0FHQVRFMTU6MDAwMS4wMGEzLmJjMzgxYzY4Jn5odHRwX2NvbnRlbnRfY2hhcnNldD1pc28tODg1OS0xJn5TdGF0ZT0yNzQzMTY5Mzgy====?~template=PCAT_AREA_S_BROWSE&mfhelp=&p_selected_area=$ROOT&p_selected_area_fh=&perform_special_action=&glb_user_js=Y&shop=NL2&vgl_artikel_in_index=&product_show_id=&p_page_to_display=DirektSearch&~cookies=1&zhmmh_lfo=&zhmmh_area_kz=8z&s_haupt_kategorie=&p_searchstring=&p_searchstring_artnr=206625&p_searchstring_manufac_artnr=&p_search_category=alle&fh_directcall=&r3_matn=&insert_kz=&gvlon=&area_s_url=&brand=&amount=&new_item_quantity=&area_url=&direkt_aufriss_area=&p_countdown=&p_80=&p_80_category=&p_80_article=&p_next_template_after_login=&mindestbestellwert=&login=&password=&bpemail=&bpid=&url=&show_wk=&use_search=3&p_back_template=&template=&kat_save=&updatestr=&vgl_artikel_in_vgl=&titel=&darsteller=&regisseur=&anbieter=&genre=&fsk=&jahr=&jahr2=&dvd_error=X&dvd_empty_error=X&dvd_year_error=&call_dvd=&kna_news=&p_status_scenario=&documentselector=&aktiv=&gewinnspiel=&p_load_area=$ROOT&p_artikelbilder_mode=&p_sortopt=&page=&p_catalog_max_results=20
read somewhere that with the 370p engine the battery pack better not has 7 cells?
what's the best pinion to use on the 370p? the ebay shop where i ordered it said not larger than 12 tooth?
http://cgi.ebay.nl/ws/eBayISAPI.dll?ViewItem&item=220595031570&ssPageName=ADME:L:OU:NL:1123#ht_3373wt_1058
« Reply #8: November 04, 2010, 01:24:15 PM »
Battery link doesn't work.
I haven't had any problems with mine.  I don't think any of us are running 7 cell packs.
ronajon
« Reply #9: November 04, 2010, 01:30:17 PM »
its this one: NiMH accupack 2/3A 7,2V Side 1300mAh - Aandrijfaccu's - Conrad Electronic
still looking for the ven-4410 (or leo x MM011) transmission gear set, no luck yet. found a couple of sites but all out of stock
« Reply #10: November 04, 2010, 02:33:49 PM »
yep, that's the right battery.   will work great.
Haven't been able to locate the gear.  Might be good to pick up one in an auction cheap,  then you'll have extra parts when you need them.
redbarton
« Reply #11: November 04, 2010, 09:34:33 PM »
VENOM M.G. GEAR SET  - Mini Giant - Venom - Car Specific Parts - Cars
ronajon
« Reply #12: November 05, 2010, 03:10:57 AM »
redbarton thx!
just ordered the set together with the wheelie bars
DaCracka69
« Reply #13: January 02, 2011, 10:08:28 PM »
I was wondering if anyone had a extra set of axles and trans? I'm working on building a tube chassis and want to keep a small stable without having to sacrifice a truck for it. Thanks.
« Reply #14: January 03, 2011, 11:09:00 AM »
best place we've found is just to keep your eyes on ebay.  they pop up from time to time.
