April 04, 2025, 07:04:39 PM *
News: Our next race will be Thursday April 17th HFAY Races .  Come Join Us!!
Pages: [1] 2 Next   Go Down
Author Topic: got my venom today  (Read 24646 times)
« Topic Start: February 11, 2008, 10:11:54 PM »
So it arrived I will be posting pictures soon, quick question, the battery has this dean plug and I don't have a charger for it?  lol the motor says fireball and thats about all I can make of it so far.
« Reply #1: February 11, 2008, 10:15:17 PM »
okay so is there a tut on the steering mod you guys have done to it? I need to get it ready by next race, also what should i do about the battery, I might be getting a charger for it in the next shipment who knows. coments suggestions?
« Reply #2: February 12, 2008, 12:08:52 AM »
http://www.one18th.com/forums/showthread.php?t=50621
    Hope this helps
CLODGUY MOTORSPORTS
« Reply #3: February 12, 2008, 12:55:31 PM »
YEah, what did you guys use to remount your servo? zip ties or did you fab some brackets out of alm?
« Reply #4: February 12, 2008, 01:01:10 PM »
it's fabricated out of aluminum angle.   the servo is mounted to it using shoe goo.  it works really well.  I'll find a pic and post it for you.
you can kinda see it in this picture
« Reply #5: February 12, 2008, 01:26:34 PM »
nice where can I get the alm? and did you use the oem tie rods?
« Reply #6: February 12, 2008, 01:27:52 PM »
oh and link those red servo savers you guys have pls Wink
« Reply #7: February 12, 2008, 01:33:50 PM »
Luke would have to fill you on what was use.  Russ would also have a better understanding as he just did his.
I just purchased the servo savers from West Valley Hobbies.
« Reply #8: February 12, 2008, 04:27:41 PM »
I have some of the aluminum angle I used if you would like some, you can come over and get it. I beleive I got it at Home Depot and its 1/2 x 1/2 inch. As for what I did just have a look at my Mini Monster gallery. The servo saver is a Kimbrough 131. Its the only red one so should be easy to find. I used a Hitec HS-81MG that I bought at WVH. Also pick up some 3mm 4/40 threaded rod, some ball ends, and 3mm nuts. I used some old Traxxas ball ends I had laying around. Its pretty easy to do if you have a vise, hack saw, dremel, drill and bits, and other various tools. If you need some help I would be happy to.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXS362&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXN679&P=ML
« Last Edit: February 12, 2008, 04:38:26 PM by Russ » Logged
« Reply #9: February 12, 2008, 05:14:44 PM »
okay I have some servos I will post some pics later let me know what they are, if they'll work and yeah I would dig some of that alm stuff if you got it.
« Reply #10: February 12, 2008, 11:49:32 PM »
Okay so I have some pictures posted in my gallery. finally. Not everything is there but soon I'll have everything up. I will have to look at yours Russ and see what exactly is involved I don't know much about the venom to just go off what I know so far.
« Reply #11: February 13, 2008, 08:00:34 AM »
Russ, saw the pics on your mini giant, I understand now what you mean, I forgot to post the servos I had, but will this work for the tie rods? maybe you can just buy everything I need and I'll buy your kennon order and we'll see what the diff is.
   TGR 401500 Steering Set with Servo Saver - AtomicMods.com
« Reply #12: February 13, 2008, 08:10:37 AM »
I dont know if that thing will work for sure. I think its for the TGR Sinister pan car. You might be able to adapt it but without specs of how long it is and what not I would probably suggest doing it the easy way. All of the items you need are available at West Valley Hobbies in Taylorsville off 54th and Redwood. If you have a small servo that will work thats fine but if not the HS-81MG works great. If you need some help making it I can help. As for the Kenon order I'm trying to wait til I hopefully get my F1 so I can see what I need for that.
« Reply #13: February 13, 2008, 08:47:47 AM »
Kimbrough 131, Hitec HS-81MG, Also pick up some 3mm 4/40 threaded rod, some ball ends, and 3mm nuts. I used some old Traxxas ball ends I had laying around..............is that all I need from there? any approx cost?
« Reply #14: February 13, 2008, 09:00:51 AM »
Approximate Prices:
HS-81MG     $22
Rod             $3
Ball Ends      $4 (Traxxas 2742X)
Screws        $Free I have some
Nuts            $Free I have some
Angle AL.      $Free I have some
Kimb. 131     $4
Tight Turns   $Priceless
Also I would call and just check to make sure they have everything. 964-1700.
Pages: [1] 2 Next   Go Up
