April 02, 2025, 04:41:53 PM *
Pages: [1] 2 Next   Go Down
Author Topic: F1 101  (Read 32277 times)
« Topic Start: February 16, 2008, 08:18:16 PM »
Okay I got my f1 in today, it has alot more hopups than I thought (since it was stock I guess anything was more than i thought) I test drove it on my track, and it pulls really bad to the right, I maxed out the controll setting, so i need to make the adjustmen on the board, only problem i can't get the dang body off! so whats the catch.
« Reply #1: February 16, 2008, 08:35:21 PM »
nm I just broke it....jk.
« Reply #2: February 16, 2008, 08:57:14 PM »
right above the rear suspension plate you can use a little screwdriver to get it off,  it's a little tricky the first time.   Make sure you only adjust a very little at a time.  Don't forget to center your controller befor you do it.
Also the helios has a sub:trim.  you use it first and then fine tune with the standard trim.
« Reply #3: February 18, 2008, 12:31:47 PM »
okay on the board the pot adjuster must be broke cuase it doesn't do anything, I used the sub trim to Right 50 and works fine, I will see when my two other F1's come in to decide how well it compares, but I will say for 100 bucks I got the carbon rear supsension, kysosho ball diff, alm knuckles alm toe bar, alm rims, bumper guard, and new tires. I'll say its a lot more than I expected for that.  And for the other fifty I got a nifty practice 01 car.
« Reply #4: February 18, 2008, 06:35:12 PM »
$100 is a great deal. I have a complaint though. IT LOOKS JUST LIKE MINE!! LOL!!!
I hope you get some different bodies with the other ones that you can race with so we can tell the difference. I guess for now I'll just have to look for the car out in front to see which one is mine.  Wink
« Reply #5: February 18, 2008, 07:31:22 PM »
I like that idea, that way you'll think you're driving your car when infact its mine....i set up my track saturday, so i am doubling up on practice time, your days are numbered Russ lol.  And yes I have two other bodies, but no promises if I choose another one, I really like this one lol.
« Reply #6: February 18, 2008, 09:38:48 PM »
well you both will be fighting with Chad for the top honors with the McLaren,   Unless I'm on my game,  then it's ferrari all the way.  Grin
I finally ordered my PN mount for my F1 along with a top shock...
« Reply #7: February 18, 2008, 09:56:06 PM »
what part number I can't ever find it.
« Reply #8: February 18, 2008, 09:58:57 PM »
for what?
« Reply #9: February 18, 2008, 11:51:06 PM »
rear dampener...
« Reply #10: February 19, 2008, 10:43:06 AM »
I got the rear spring.    I still need the damper,  it was out of stock everywhere I looked.
« Reply #11: February 19, 2008, 10:57:41 AM »
oh okay, I figured as much but I thought I'd ask.
« Reply #12: March 07, 2008, 09:31:09 AM »
They have them on ebay. Or I'll sell you mine.
I took my rear damper off. I just could not get it to work right with my motor mount. I think I just want the rear srping thing like yours. For now I'm just running the Atomic shock that came with my damper plate. I dont like it that well but I need it to because just the carbon rear plates alone wont hold the car up. Eventually I will upgrade my motor mount to the PN one. That is if I decide to keep the F1. I'm really frustrated with it right now.
« Reply #13: March 07, 2008, 09:45:47 AM »
don't give up on it.   once you get it handling the way you want you will like it.  Cool
« Reply #14: March 07, 2008, 10:25:48 AM »
Believe it or not... I got one of my boxes of RCP put together last night. WooHoo!! I set up a wide oval in my front room. LOL!! Anyway I ran my F1 on it because I had fixed some things and wanted to test. Anyway it seemed to be ok turning to the right or clockwise but would spin out easily to the left. I was going to try some shims between the side plates and the chassis to correct it. I presume its caused by tweek?.
I tried to fix the stutter in the steering. I took it all apart and cleaned the pot with motor spray and cleaned all the servo gears out. It works way better but there is still a slight stutter about 10% of what it was.
Pages: [1] 2 Next   Go Up
